Manually selecting Lightbridge II Freq
This seems like an obvious question, but I haven't been able to find an answer -- on or off the forums.
How, exactly, does one manually select the frequency the P4P will use to communicate with the RC? I know (or believe) that, by default, it will bounce back and force between 2.4GHz and 5.8GHz, depending on signal strength. But a number of sites suggest it is also user-selectable. How does once force the bird to only use 2.4GHz, for example?
Thanks. P4P is on Santa's sleigh, so I haven't been able to noodle around with DJI Go.
Can I assume that, when set to 2.4 only, the Lightbridge connection on the P4P will be comparable to what I experienced with my dearly departed P4?
