MAC will not mount SD card
Discussion in 'Pro/Adv Discussion' started by drumbum, Mar 27, 2016.
  1. drumbum
    Hi all,
    I just returned from a film shoot with my P3A.
    The 64gb SD will not mount on either of my IMAC/MAC book.
    I viewed the videos on my iphone while the P3 was powered up so I know there are video files on the SD.
    But I cannot access them via my computer.
    Any ideas?
    Cheers
  2. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    It is a pleasure to welcome you to the Phantom Pilots forum. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
    Use a card reader with your PC. And do not forget the videos stored on the device & the video captured on the card are not the same thing. Be sure the card has content on it.
  3. alokbhargava
    San Francisco, CA
    Usually you get SD card adapter with every micro ad card you buy. Use the adapter to mount your micro SF card. These adapters are very delicate, so you need to buy one good USB adapter that can read 64 GB.
  4. drumbum
    Hey guys,
    sorry I should have provided more information.
    I have used this card and an SD card reader several times before with this P3. Today I did the same as every other mission but for some reason it just wont mount.
  5. mikeve
    Merrickville, ON Canada
    Try using Disk Utilities to mount it.
    Lefty63 likes this.
  6. LuvMyTJ
    Staff Member
    Maybe it went bad. Try reformatting it.
    The included card readers don't work half the time. I bought a Kingston Mobile Lite G4. It is USB3 and is double sided so you can put one SD card in it and also a micro SD and you can see & access both at the same time.
  7. alokbhargava
    San Francisco, CA
    P3 also has a micro USB slot. Use a cable to connect to your Mac and see the contents. This is a temp solution. Once you get the contents out, format your SF card before using it again.
  8. matti
    There might be few failure points of failure and workarounds.
    My SD card adapter is flaky so sometimes it needs another try to mount it. I'm still too lazy to buy a new one...
    Connecting via USB cable to the DJI gimbal's USB has always worked although I have had some bad USB cables.
    I usually just delete the files from the SD card but every now and then I reformat it in the DJI (it is also possible to reformat on a Mac/PC but make sure to use MSDOS (FAT) with Master Boot Record partition map.
  9. drumbum
    Hey guys,
    thanks all for the input.
    Some trouble shooting found BOTH my SD card readers had failed even though they had a blue light to indicate power.
    Used a friends reader and it was fine so I have ordered a new card reader,
    regards
    Lefty63 likes this.
Similar Threads - MAC mount card Forum Date
Immaculate Phantom 4 with Nvidia Shield K1 (Price Lowered $750) Classifieds Jan 9, 2018
how to get cached video from controller to MacBook Pro Phantom 4 Pro Discussion Oct 27, 2017
Should I get a MacBook When Operating my Phantom 4 Pro with an iPhone or iPad? Phantom 4 Pro Discussion Oct 25, 2017
Mavic Pro stuff, Macbook, Nexus 6p, iphone 6s, Note 5, Gear S3, LG G5 Classifieds Sep 30, 2017
P4P files won't copy to my Mac Phantom 4 Pro Help Sep 23, 2017
