Lowering the live feed from 720p to 480p
I have a phantom 3 standard that i’ve had for almost three years. It works good still. Is it possible to lower the live feed from 720p to 480p? I wanna do this so the app wont take up so much battery life and to get less lag. Is it possible to like maybe hook the drone to a computer and modify the drone’s code? Thank you.
Unfortunately, You cannot to my knowledge dumb down the footage being received. It shouldn't have a dramatic effect on battery life, and as far as the "lag" or latency. Check to make sure your connectors on the gimbal have likely rattled loose. They'll need to be cleaned and tightened to get that "like new" connection back. You'll need to carefully remove the gimbal to expose the connectors and clean then reseat the cables. Make sure everything is snug. Reinstall the gimbal and give it a test flight. Should be much better. Best of luck!
pitchpost
