Low Battery Level "Go Home"
Discussion in 'Phantom 2 Discussion' started by alibaba, Oct 6, 2014.
  1. alibaba
    In my NAZA Assistant software I have the following settings:
    Low Battery Level - "Go Home" is checked. (This is the default setting)
    My question is the following:
    What will happen if I uncheck the "Go Home"and the battery level hits the low battery level?
    What will happen when it hits the Critical battery level will it go home still if I have the "Go Home" unchecked?
    I don't understand the implication of unchecking the "Go Home" on low battery level.
    In the meantime I have a timer setup for 12 minutes and only fly for 12 minutes.
    Thanks and I hope someone can clear this up for me.
    Equipment
    Phantom 2
    Zenmuse H3-3D Gimbal
    Go Pro Hero3 Black
  2. IrishSights
    Bangor, Northern Ireland, UK
    Re: Low Battery Level "Go Home"
    If its unchecked the logic is it will not go home. When it gets to critical it will auto land, wherever it is. Using a timer is not a failsafe but an indication only. If you have strong headwinds you will need to plan for that and come home early. Some of us do not like the auto go home as we like to be more in control of what and when it does something. Each to his own. It will try and estimate to get home before battery is critical but as it does not know of any headwind its not always right
    Sent from Samsung S4 via Tapatalk
  3. IrishSights
    Sorry I did not complete the answer. When it gets to low level and go home is unchecked it just warns you by the red leds flashing as far as know. I have never let mine get that low.
  4. alibaba
    Thanks for the quick reply. I really appreciate it.
Similar Threads - Low Battery Level Forum Date
Litchi waypoint low battery level question Control (Go, Litchi, etc..) Dec 4, 2016
Best Low Battery Warning Levels Standard Oct 25, 2016
What's your P4 battery low battery warning level? Phantom 4 Discussion Aug 31, 2016
Professional RTH fails to trigger at low battery level Phantom 3 Help Jun 20, 2016
Low and Critical Battery Levels Standard Dec 30, 2015
