Loud Speakers and the compass.
Discussion in 'Pro/Adv Discussion' started by Trackman1, Feb 12, 2016.
  1. Trackman1
    Ontario, Canada
    Since I can't fly due to snow and cold for the last 3 days, and my battery was full. I thought it a good idea to play around with the go app and learn what everything does when ever I have a moment.
    So I left the phantom on a table that is on 5-6ft away from some home theater speakers.
    Question 1
    Could this harm the compass? Or is 5-6 ft safe?
    I know when I calibrated the compass the mod value was 1400. Last night it was 1700.
    But when I look on it's map view the airplane symbol points exactly in the direction the phantom is facing.
    If I move the phantom around the symbol points correctly.
    Question 2
    Is the airplane symbol pointing in the right direction a good indication of proper compass calibration?
  2. 4wd
    4wd
    North York Moors
    A lot of car doors have speakers in them - probably nearer than yours at home.
    It might do, the app will tell you if things are not right.
    It's a good idea to manually look at the values in the app before you start anyway.
  3. ianwood
    ianwood Taco Wrangler
    Lost Angeles
    Check the mod value outdoors before you recalibrate it. If the check you did at 1,700 was away from all metal and before calibration, that is bad. Indication that the compass be magnetized. You may need to degauss it.
  4. Meta4
    Meta4 Moderator
    Staff Member
    That's hard to be say. It might be OK or maybe not.
    Further away would definitely be better.
    No. It is possible to "successfully" calibrate the compass in a bad area and everything will look right in the distorted magnetic field where the calibration was done.
    If the Phantom flies straight and does not bring up compass errors in flight, that indicates a good calibration.
  5. Trackman1
    Ontario, Canada
    The mod value was out doors. Can't go out there now. I was wondering about degause. But have not noticed and option to do it.
    Not planning on doing anything until I can take it out doors like you said.
  6. ianwood
    Lost Angeles
    There is no degauss option. It's a manual process. And it's not an exact science.
  7. m0j0
    Sounds like something that should be done by a pro...
Similar Threads - Loud Speakers compass Forum Date
Cloud Sea Sunset Photos and Video Jan 3, 2018
Clouds Phantom 4 Pro Discussion Dec 14, 2017
So loud....? Pro/Adv Discussion Dec 10, 2017
phantom 4 + Adobe creative cloud Phantom 4 Discussion Dec 8, 2017
searching for cloud 9 (like a beginner) Photography and Film Dec 3, 2017
