Lost F****** signal AGAIN.....
Discussion in 'Standard/4k Discussion' started by Brian1888, Mar 30, 2016.
  1. Brian1888
    SO annoyed with this issue....straight up flight and at about 170-200m i keep getting a lost signal....RTH!
    Signal boosters i here ye say....i say im not supposed to have to worry about that for the price i paid!
  2. eaglegoaltender
    Straight up - as in 'near overhead flying"?
    What was the orientation of your antennae's? Should be pointed "parallel" to the ground when flying straight up n overhead. Perpendicular to the ground when flying out and away from you.
    Believe me......it works for obtaining a strong signal..........flat side of the antennae's - not the tips is where you get the strongest signal.
    Brian1888 likes this.
  3. Fdnyfish
    Barnesville, PA
    your signal will degrade if you are straight over your head at that altitude
  4. azpilot61
    Arizona
    Straight up for me with DBS mod unless I'm pointing towards the aircraft I will loose signal as well. Even with just the stock antenna's I have to point the controller or the antennas as the aircraft. Now I just move about 50 feet in front of me and go up.. No problems
  5. Brian1888
    Thank you for the reply. I called Dji agent where i bought the drone....they told me to KEEP the antenna pointing straight up during all flights...
  6. eaglegoaltender
    Poor advice............
    Have you seen this before..........note the antennae position for overhead flying or near overhead.
    The optimal position is the antennae perpendicular to the ground with the flat sides of the antennae facing the quad.
    [​IMG]
  7. Brian1888
    My RC has only 1 antenna and no flat sides....but i take your point and advice. Thanks Again..will try this out :)
  8. azpilot61
    Arizona
    On the P3S if the aircraft is straight overhead, the antenna should be straight out from you horizontal as this will allow the antenna to work best. However the internal antennas then are pointing straight out in the same direction. Just easier to move out a bit to avoid low or lost signal
  9. rcheing
    Did the P3S come with only ONE antenna? I thought they all came with two antennas stock?
  10. azpilot61
    Arizona
    P3S comes with 1 external 5.8 video and then the 2 2.4 rc signal antenna's are inside.
  11. robsquad
    Wolverhampton, UK
    point it sideways, winner either way
  12. Brian1888
  13. dirtybum
    Unless I'm misunderstanding the way your orientating, I believe you have it all wrong for 5.8 signals the flat side of signals is for 2.4 antennas.this was posted in the standard section right
  14. TheLightSpeedz
    Holy, poop. Really Dude?
  15. TheLightSpeedz
    BTW the "price you paid"? Did they take a arm and a leg? Lol. You bought the Most inexpensive DJI Drone available. I know it's still money but you make it sound like for the "money you paid" that it should double as your financial accountant.
  16. rich146
    You shouldn't be flying higher than 120m !? Signal loss will be the least of your worries if you hit a private plane or helicopter.
  17. Brian1888
    Yes...what i paid....it maybe the most inexpensive....but to me and im sure a good number of other folk...its a lot of €!! And to be limited to very low flights....not good enough. thanks for your input.
  18. Brian1888
    Where i live/fly there is no airports/landing zones for 100 miles. But i take your point.
  19. Tony Cowan
    Well if you listen to them. The. You will never know. I will never fly over head. At least go 30 feet out. But as stated. Horizontal if overhead. They clearly show a video for optimized signal in certain flying conditions. Once you know how the signal goes out. You should be fine. 200m is up there for sure. I did go 1640 once. But I was 500feet out as well.
  20. eaglegoaltender
    Not sure I understand your comment DB? This is where I obtained the info I use for flying............
    As taken from Wiki-DJI
    P3A/P---Position Remote Controller antennas properly: parallel and pointing upward. Make sure the flat sides are facing the Aircraft at all times; keep changing your body position and antennas tilt, if necessary, to keep wide flat sides of antennas pointed at Aircraft. This is more important the further the Aircraft is from the RC. Need to know: NEVER point tips of antennas directly at the P3 (like a gun barrel) - this is the lowest signal level situation.
    Phantom 3 Advanced remote controller - The video downlink and aircraft remote control system operate at 2.4 GHz.
    [​IMG]
    P3S with single antennae.....The Phantom 3 Standard remote controller features a 2.4 GHz WiFi Video Downlink, 5.8 GHz aircraft transmission system (Wiki-DJI)
    [​IMG]
Similar Threads - Lost F****** signal Forum Date
Satellite conection lost? Phantom 2 Discussion Yesterday at 4:01 PM
Litchi connection lost Control (Go, Litchi, etc..) Sunday at 12:51 PM
Lost video comms while in flight p4p+ Phantom 4 Help Wednesday at 2:06 PM
Standard P3S Weak/Lost Video Signal Phantom 3 Help Jul 15, 2017
Lost signal over water, took a swim. Standard/4k Discussion Jul 14, 2017
