loss of control
Discussion in 'Phantom 1 Help' started by jimmyzshack, Apr 21, 2014.
  1. jimmyzshack
  2. Jacobrichards91
    It sounds to me like normal operation. the phantom is programmed to come home if the battery gets too low, the way that your video showed it dropping is normal. thats how it lands in fail safe mode. I would get a battery tester. I charge my batteries to 12.6v and i usually quit at about 11v. the failsafe activates at 10.6v
  3. jimmyzshack
    i tested the battery after it landed it was at 48%. I'm trying to figure out why i lost control of the phantom started very delayed response to control to complete loss of control and it finally went to failsafe and landed at home. i was no farther than a 100' when i lost control of the craft.
  4. nwillitts
    i had the same thing happen to me once.never figured it out.i think it may have been weak transmitter batteries.
  5. Jacobrichards91
    now that you mention the delay and then the fail safe, it does sound like weak transmitter batteries. if it was a "flyaway" it would just maneuver on its own. also, make sure when you are flying that your antenna is bent at a 90deg angle upwards, that way you know you are getting the best signal.
  6. jimmyzshack
    these where brand new batteries put in the first day of owning, but i put new ones in have flown it 8 more times and it hasn't happen again. how many flights is avg for the transmitter batteries? thanks for the replies.
  7. nwillitts
    that's a good question.
Similar Threads - loss control Forum Date
Professional Fix to loss of connection between Remote Controller and Phantom 3 Pro Phantom 3 Help Aug 7, 2017
Phantom Pro 4 loss of camera control Phantom 4 Pro Help Apr 17, 2017
Professional Complete loss of control of phantom 3 pro Phantom 3 Help Oct 13, 2016
Recovering from a loss of control link Phantom 2 Help Sep 9, 2016
First loss of control and return to home. Standard/4k Discussion Aug 17, 2016
