ive found a fix for this I downgraded the firmware back to 1.5.7 and just tested it now going double the altitude and distance with still good signal
I had to download the firmware from here
DJI Phantom Accessories & Tips - Phantom Help
then put this file onto formatted sd card
turn on drone and controller
connect to dji go
now insert sd card into camera
drone will start to downgrade progress shows on app
when finished turn everything off and on again
that's it
It was much better after I did the downgrade,My p3s hasame problem like yours but losing video signal at around 90-100 meters, I think it should have been much further range than that.
After downgrading, how is the range of your p3s ehen flying in urban area?
I will down grade my p3s firmware today following your post...
My p3s has the same problem like yours but losing video signal at around 90-100 meters, I think it should have been much further range than that.
You can only go back one firmware so if your on 1.6 then you need the 1.5 firmware.
