Losing Camera Signal At 70 Meters
Discussion in 'Pro/Adv Discussion' started by Andy Mason, May 18, 2016.
  1. Andy Mason
    Hello All
    A firstly post for me and a newbie in terms of quad flying. I recently purchased a P3S and flown this on six occasions, and my initial impressions are fantastic and really impressed on how easy it is to fly. However I have one issue.. at around 70 meters I am losing the picture to my IPhone (6) and last night I tried my Ipad but alas the same result. One thing to note is that I have full control as far as I dare to go and fly, estimate around 200 meters before I lose sight of the quad with the picture coming back, again, around the 70 meter mark. To add to the confusion, and it doesn't take a lot, the camera is recording crystal clear images to the SD card all of the time.
    I have made a windsurfer out of card and foil from a template that I found on the web but again no picture after 70 meters. All software is up to date and I am really in need of some assistance here as this is spoiling my enjoyment.
    Has anyone got any ideas on what I can do to get this fixed?
  2. Mimoid
    The Standard uses WiFi (and not LightBridge as the Adv and Pro models) with an inherently much more easily scrambled signal transmission. However 70 meters is not much, you should get at least 300 meters, or more, even in a suburban area.
    I would start with eliminating as many WiFi sources as possible. Switch the iPhone to airplane mode, and try to move away from possible other signal sources, like nearby mobile antennas and also homes with WiFi routers and stuff.
    Remember that trees and other obstacles are weakening the signal to great extent, try to make sure to have a clear line of sight between the remote and the drone. The position if the antenna is also important, but you already know this.
    //Tom
    #2 Mimoid, May 18, 2016
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Have you tried flying in different locations to rule out interference as a cause?
Similar Threads - Losing Camera Signal Forum Date
Losing camera feed and app connection at short distances. Standard/4k Discussion Jan 3, 2017
Losing the camera setting icon Pro/Adv Discussion Sep 22, 2015
Losing Wifi after rebinding new camera-Need Assistance Phantom 2 Vision + Help Apr 18, 2015
Broke your camera? Want to replace it without losing wifi? Phantom 2 Vision + Discussion Dec 9, 2014
Phantom Vision Camera Losing Its Mind Phantom 2 Vision Discussion Mar 17, 2014
