LOS Calculator?
Is there a website that can roughly calculate the height you'd need to fly to keep LOS on your drone given a certain distance?
I want to use Litchi to fly my P3A straight to my friends house. It's about 7500ft in a straight line. I just want to know the altitude I can set it to keep LOS with the controller. Right now I have it at 300ft, which is just a guess. The terrain is fairly flat the whole way.
I always wondered what the formula was for calculating angle of altitude at and given distance. Even if it's just assuming a flat terrain. For example: on super ling distance flights over water. Even at 9mi it seems like the bird is only 10deg off the surface.
Do you live in an area that is perfectly flat with no obstructions... such as houses or trees? If not, then any such calculator will not help.
Sure it would. Just like I said if at 9mi you need to maintain a 10deg angle for LOS then if anything gets in between you know it's an issue.
I'm not sure that this is a well-posed question. Loss of LOS can be due to a number of factors, and terrain is only one of them.
  1. At the global level, the curvature of the earth is going to obstruct LOS at some altitude-dependent distance - simple Euclidean geometry. Valid over bodies of water.
  2. On a more local, topographic level, mountains, hills or even more subtle elevation changes may cause loss of LOS - a more complex calculation requiring a DEM for the terrain. Valid over bare landscapes.
  3. Even more locally, trees, buildings and other structures may cause loss of LOS - very difficult to calculate since even the best DEMs do not, typically, include buildings and vegetation. Probably the most common obstruction to LOS.
In all three cases, the point of loss of LOS is very sensitive to the elevation of the observer, and so some or all of these four factors will interact to define the limiting distance. It would be difficult, if not impossible, to implement any kind of general solution to that problem without detailed datasets that just don't exist.
That said, there are mapping programs that calculate visibility from specified locations and elevations due to simple topography, and so if buildings or vegetation are not the limiting factor, then those programs could be used to estimate necessary altitudes.
Why do you need LOS if you are flying with Litchi? Litchi continues mission even if signal is lost.
But anyway you can use following formula to calculate LOS for a known height:
distance to horizon (miles) = sqrt [ 7 × h (feet) / 4 ].
In ideal condition one can see up to 3.5 miles due to earths curvature. 7500' is just 1.42 miles.
If you are flying at 200' and above, you should not have any problems at all.
Reactions: wallix
Thanks! This helps a lot. I read that while Litchi continues after signal loss, it will lose any custom gimbal controls at that time. Is that not true? That's why I was asking. I didn't want to waste time trying to program any POI if it would all be rendered moot at signal loss.
400 ft is less than a 10th of a mile so this is a geometery problem (note I did not say "just a geometry problem" because I never did well in geometery)...
X is something like (actually less than) 1, Y is something like 90 (9x10). What's the angle? I don't know but I bet it's less than 10 degrees.....
But on the other hand we have the fact that radio waves actually do NOT travel in a straight line. They curve back down towards the surface of the earth just like a golf ball. So that is an advantage, but the question is, how quickly does it start to curve? Does it take 1000 miles, a 100 miles, 10 miles, 1 mile? I don't know. In fact, I don't know much.
Yes if there is no signal, you can't maneuver manually. Also even if there is no video, you can't do much.
Yes, I'm only doing this because I have another friend with a P4 who is also trying to make it to his house, too - but he's never heard of Litchi so he only makes it 2/3 there before it comes home. I want to beat him with my crusty old P3A.
Competitive spirit is good to have but one should know the limits else you reach a point of no return.
Design your experiment on a smaller scale first and slowly expand to know its limits. Best wishes.
shimuafeni fredrik
