Loose components after crash
Discussion in 'Standard' started by cas_per_m, Jan 11, 2016.
  1. cas_per_m
    Hengelo (G), The Netherlands
    Help required!
    After an unfortunate encounter with a branch my P3S smashed into the ground, about 6 meters lower.
    Apart from apparent body damage (total loss) some components on the main board are bent and loose.
  2. Sinisalo
    Buy a phantom 3 Advanced using a student discount you can get it shipped for $717 DJI Educational Discount | DJI Store . Sorry for your loss, it looks like it is totaled. I wouldn't use the battery either if you do buy the advanced. You might be able to sell the crashed parts as a bundle on ebay, i have seen a few of those. You for sure can sell your controller.
  3. cas_per_m
    The Phantom will be going out for a repair assessment. After that I'll get a quote, based upon which I can decide what to do next. The P3A seems awesome, yet first I have to investigate my options..
    Untill that time: enjoy the last moments of the P3S. Just flying around town in mediocre wheather, when suddenly..
    Click here to hug that tree!
  4. cas_per_m
    Well, after quite a while I managed to get an update on the repair quote. Tuned out that the shop where I bought the P3S (and where I returned it for repairs) messed up their system, causing the delay.
    Anyhow, a grand total of €515 (including VAT) is the cost of this tree-hugging accident. This is why I decided to get a new P3S instead. With the educational discount the total difference was around 20€. No brainer. (Just got the new bird today. ****, was great flying after such a long time :) )
    My broken P3S is being returned, as I wanted to keep it for parts (gimbal, spare controller etc.).
    Especially the spare battery is a big plus. BUT:
    Will it be okay to use the battery that was in the drone at the time of the crash? DJI did not put it on the repair quote as ''to be replaced.''
    What do you guys think?
  5. Bordo_bereli51
    Do you see some external damages on the battery? Does the LEDS gets on when you push the button? I would try to start the new phantom 3 s with that battery and check the voltage and battery life. DJI Go will tell you if there is an damage to any of the batterycells.
  6. cas_per_m
    Thanks Bordo!
    Does anyone have a clue whether or not DJI has checked the battery?
    I suppose they would have, but am not sure at all..
    Maybe they sent it off without checking?
  7. Squirrel!
    If the battery doesn't appear damaged, I would just use it.
    Oh! And can't view your video, you set it to private viewing only.
    I sympathize with you on your loss but congrats on the new drone!
  8. cas_per_m
    Ah, I see.
    Must have changed that accidentally.
    You should now be able to see the drone crashing into an overhead branch
  9. Squirrel!
    Bummer...
    cas_per_m likes this.
  10. AngryBird
    Lithuania
    Did you lost control of the aircraft? Or just did not noticed that branch?
  11. cas_per_m
    Well, combination of factors.
    Noticed the small tree/branch at the right hand side of the road, yet I wanted to fly off to the right into the field. Wind gust lifted the drone a bit, whilst I tried to avoid the small tree.
    Perfectly dodged that tree, yet I did not notice the overhead branch. This was amplified by the wind gust, as it lifted the drone. Kaboom, damage done
    Squirrel! likes this.
  12. AngryBird
    Lithuania
    I`m sorry to hear that. After stories like this I want to be more and more careful while flying.
    Are you planning to keep the broken one for spare parts? Or maybe you could sell some parts?
    I`m looking for RC`s 5.8G antenna with cable. I accidentally dropped my RC on the ground and broke 5.8G antenna, moreover it cut the cable in to two pieces.
    Let me know you are interested in selling it.
  13. cas_per_m
    Well, I have indeed been thinking about selling some parts.
    However, I do want to do the Inspire tablet holder mod first. If I accidentally cut a wire in that process I at least have a spare remote. I might decide to sell the other remote in case the mod works out well. In that case I'll let you know! :)
  14. cas_per_m
    Well:
    She's up and running again!
    Last Saturday I decided to take it out for a bit of flying during a photowalk with friends.
    Results? Click the link for the video :)
    Compilatie 12-03-2016
  15. Squirrel!
    Did you repair by yourself or someone else did the work?
  16. cas_per_m
    My insurance broker covered the loss, after which I bought a new P3S. This arrived about a week ago.
    Hopefully my crashed bird will also return soon , so I can do the Inspire Mount Mod to the controller. (and have a third spare battery etc)
  17. Squirrel!
  18. cas_per_m
    Just a final update.
    The broken P3S has been stripped for parts, while the controller has been modded to an Inspire-holder one.
    And to top it off: time flies when you're having fun flying!
Similar Threads - Loose components crash Forum Date
does anything come loose or need tightening?? Phantom 4 Pro Discussion Jan 12, 2018
Loose screw or something in phantom 4 Advanced Phantom 4 Help Jan 11, 2018
4 Adv. gimbal pan completely loose Phantom 4 Pro Help Dec 14, 2017
If you loose video signal, will it start back recording? Phantom 4 Pro Discussion Nov 30, 2017
P4 Pro Stock UV Filter glass came loose! Phantom 4 Pro Discussion Oct 23, 2017
