Looks like I will be posting in the plus forum from now on
Discussion in 'Phantom 2 Vision + Discussion' started by ccase39, Feb 19, 2015.
  1. ccase39
    I upgraded my Vision to the V+ 3.0. Should be here tomorrow. Cant wait to check out the differences. Im assuming the initial start up procedure is the same?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Re: Looks like I will be posting in the plus forum from now
    This might be a little too informative for you, but it's a nice step-by-step guide to get everything setup.
    #2 msinger, Feb 19, 2015
  3. ccase39
    Great thanks! Im assuming I will need to install all new drivers and software for the plus Including the RC assistant and Camera?
  4. Meta4
    Meta4 Moderator
    Staff Member
    The plus is very similar to the Vision.
    Just make sure that you untick FPV Mode in the app settings and you'll have nice smooth video that the Vision can't ever hope for.
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
  6. ccase39
    When downloaded the FC200 my pc is trying to open it in windows photo viewer which is not compatable with the file. Is there a better program to open it with? I guess photo viewer is my default.
  7. general01
    The software is the same for both models(I know as I have both) drivers too
    The v+ is way better in the video then the non plus vision ever will be(unless with a aftermarket gimbal)
    If you want to downgrade the firmware to 1.08 you can(it works I have done it) just you have to use a windows machine
  8. flyNfrank
    Indy, USA
    Just wait until you watch your 1st recorded video of the flight back. You feel as though you now have a professional video system. It is amazing.
  9. ccase39
    Did you guys notice that upon takeoff when he was in "idle" the rear right propeller was not spinning as the others were? Was that just the way the sun was shining through them or what? I watched the shadow thinking it was an optical illusion but saw the samee in the shadow.
  10. Meta4
    Meta4 Moderator
    Staff Member
    Stroboscopic illusion. The shutter of the camera opening 25 times a second (or so) can make it look screwy.
    If it flies straight all is good.
Similar Threads - Looks posting plus Forum Date
Looks like a stress crack? Standard/4k Discussion Monday at 9:01 PM
Looks lik is U.K users are gonna get screwed over. News Jul 22, 2017
Standard Dji go before p4 looks different Phantom 3 Help Jun 12, 2017
Standard Live feed looks like snow or over exposed Phantom 3 Help Apr 1, 2017
P3P created video looks terrible Pro/Adv Discussion Mar 30, 2017
