My hardshell backpack case broke my antenna at the base.I thought about super glueing it.... but i don't think it will be able to rotate once glued... anyone have any suggestions? Or Potentially a stock antenna available?
What's the most affordable upgrade?super glue it, otherwise nothing you can do besides opening the controller and running all new cables and at that point you might as well get a new antenna thats better
The panels definitely do give you more range - at the expense of the directionality. I do like my modded RC with the r-SMA connectors since it allows me to 'mix and match'. One upcoming project is to put those connectors on the stock antennas so I can more or less have it all. From little 3 dB omnis that fold up smaller than stock to 12 dB flat panels for maximum range.true, I have some small 6dbi antenna's more omni but still get some good distance from it. I could get those flapper type of antenna's, many say it even goes further then stock. just so many options when you have that.
