Hi all,
I'm still fairly new to drone flying and learning on the fly (no pun intended).
I have a P3 STD and would like to fully understand and be educated for flights from a boat. I need to have someone explain in detail the following relating only to a P3 STD Control:
Which Control Settings (S1 & S2) for over water flight
I'll start with these questions before I go into brain overload.
Thank you for your time and patience.
- Position locking (if any) to return to controller (if possible)
- Can the controller be set as the home position ?
- Can P3 be switched into GPS mode once positioned over water to allow for stability in video's, then switched back out to manual control ?
