Long Yellow blinking lights- GPS Problem? Area?
Discussion in 'General Discussion' started by JoeJITSU, May 11, 2014.
  1. JoeJITSU
    We've always had problems with GPS in our house and I just received mine within a few hours. I do the Compass Calibration and I just can't get through the second part. It ends up being long yellow lights blinking. I am thinking it's a signal?
  2. Gizmo3000
    Sherman Oaks, CA
    It's a lot to take in, but take the time to read the manuals carefully.
    -the Compass dance has nothing to do with GPS signal
    -the yellow flashing you're seeing means the Phantom is in Failsafe mode, which most likely is occurring because you've started your Phantom without turning on the Transmitter (Tx).
  3. JoeJITSU
    Well, I'm not thinking its the Remote Control because I did manage to start the motors up.
    When I toggle the right switch 6x, I get the solid Yellow. I turn the Phantom2 360 degrees and it then turns green, I then point the front to the ground and then spin it 360 degrees. I then get a Long Yellow blink. I saw on another forum that a lot of the newer Phantom 2's are also having this same thing happening to them.
    I have not took it out for a test flight yet but I plan to send it back to DJI on Monday if it doesn't get solved then. Thank you and I look forward to offering some help as well in the future. Thank you guys
  4. Dalite
    Brunswick, GA. USA
    Try to do an Advanced IMU Calibration in the NAZA Assistant to see if it corrects the problem or throws an error code.
  5. sar104
    Los Alamos, NM.
    Surely slow yellow just means a successful calibration and ready to fly with no GPS, which is not very surprising if this is being done indoors. Fast yellow would be failsafe.
  6. JoeJITSU
    That's what I'm thinking. Gonna try at the park in a few hours.
    Should I download NAZA?
    I downloaded the Phantom assistant but not the NAZA, from what the site explains, NAZA is only for advanced flyers only, should I download it anyways ?
  7. JoeJITSU
    Re:SOLVED
    Works outdoors. I was trying to calibrate indoors. Thanks
Similar Threads - Long Yellow blinking Forum Date
The Litchi app: Anyone had or still has it? For how long and do you have any remarks about using it? Control (Go, Litchi, etc..) Wednesday at 5:02 PM
Synchronising between Laptop and Iphone 6 no longer works General Discussion Aug 13, 2017
Recording management: few long or many short? Photos and Video Aug 12, 2017
Phantom 4 Longevity Phantom 4 Discussion Aug 9, 2017
August 7 Month long DJI firmware failure. Phantom 4 Discussion Aug 7, 2017
