capodrone81 said:any oem screw that you remove will have a dab of blue loctite on.. i recommend using the same blue loctite when reinstalling those screws... extremely small amount fyi, the tip of a tooth pick is plenty rubbed against the thread of the screw....
Hughie said:capodrone81 said:any oem screw that you remove will have a dab of blue loctite on.. i recommend using the same blue loctite when reinstalling those screws... extremely small amount fyi, the tip of a tooth pick is plenty rubbed against the thread of the screw....
It may be blue ...... but it is not Loctite. Loctite eats DJI plastic for breakfast.
Edit: It's no coincidence that the cookie monster is blue
https://www.youtube.com/watch?v=I5e6ftNpGsU
Emmbee said:Hi,
What type of loctite is suitable for use on phantom, where it's a screw to plastic connection..
Mark
