  1. ANFIELD SCOUSE
    Hi guys/girls, i'm new to this forum so hello to you all.
    Got my phantom 4 yesterday and took it out for a test flight, i live streamed it so my friend could see and the picture was fine.
    Today i did the same and the picture appeared to be really white, i have obviousl phantom 4.png y been playing with all the settings on the drone so i guess it's something i have done but does anyone know what it may be?
    Any help would be greatly appreciated
    Many Thanks
    Colin,
  2. phlyer
    Northern Ireland
    Adjust the exposure with the little wheel front right on the controller.
    Blue Bird likes this.
  3. ANFIELD SCOUSE
    Cheers will give that a try, can you only livestream in 720p?
  4. Blue Bird
    Dade County, Florida
    If you are streaming on FB, you can use 1080P but set to 30FPS or lower. Anything higher will become choppy.
  5. ANFIELD SCOUSE
    Where would i change the setting for that? In terms of my original post and changing it with the button on the controller what's the best setting to have it on?
  6. Blue Bird
    Go into camera menu on top of camera settings, then select the video camera.
    Select 1080P with a frame rate of 30. While on the settings, click on the wrench icon and choose Vivid or what ever you desire.
  7. ANFIELD SCOUSE
    Ok cheers, really appreciate your help.
    I have another question, i calibrated the compass but shows only 1 compass with the yellow dot, is this normal?? [​IMG]
  8. Blue Bird
    Yes that is normal. The second IMU and compass is sort of a back up should there be an issue with the primary compass and IMU. It is for redundancy.
    #8 Blue Bird, Aug 4, 2016
  9. ANFIELD SCOUSE
    cheers for your's and everyone else's help.
Similar Threads - Live stream camera Forum Date
live stream - multiple camera angeles flip camera around or share with a phone General Discussion May 23, 2016
Problem with live stream on phone from drone camera Phantom 2 Vision Help Dec 28, 2015
Live stream from any HDMI camera News Mar 2, 2015
Live Stream From FC40 Camera Phantom FC40 Discussion May 5, 2014
Camera help is it a live stream or what? Phantom 1 Help Dec 16, 2013
