Live Another Day
Discussion in 'Pro/Adv Discussion' started by Milfodd, Dec 16, 2015.
  1. Milfodd
    I thought I'd share my close dabble with disaster this week as a warning to all excited, yet inexperienced pilots out there.
    The plan was to visit a local waterfall and capture some shots from its base all the way to the top and beyond!
    The terrain was rocky and generally uneven at the bottom. I selected a large, flatish rock and went through all pre flight checks and calibrations. Take off went well and I was soon hovering over the pool at the base of the falls before soaring high into the sky. I picked up the shots I was looking for along with some video and decided to call it a day.
    I returned my Phantom to six feet above the take off point and descended slowly. What I had not anticipated was the turbulence generated by the rocky/boulder strewn terrain. The Phantom would not hold steady and I feared that it would slip or tip if I attempted to land. I scanned the area and spotted a flatter spot and went for the landing. Alas my fears came to pass and it side slipped towards the waters edge. I panicked and sent it the wrong way. The props clipped a small bush flipping it over onto the rock and it slid straight into the water! I powered off as soon as it flipped and had it out of the water within 5 to 6 seconds. More than enough time for it to get soaked and the dye to run red. I had the battery straight out and dried it the best I could on the way home. It sat in a rice for three days and I set up a hairdryer to gently waft it from many angles for long periods of time. After four days I plucked up the courage to insert another battery and power it up. Speakers beeped and lights flashed as one would hope and all the engines fired up! The test flight went well and all seems to be in order. I got lucky.
    I know I flew in a location beyond my current skill set and did not take the time to correctly assess the situation. There were much safer landing spots about 100 yards out which I could have selected but I was too focused on landing NOW!
    Anyhow, to all my fellow new pilots. Practice. Take your time. Don't rush. Look around you. Breathe. Unless your battery is about to die you have time to think things through at your leisure. The waterfalls of the world will wait. Build up those skills. Live to fly another day!
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Adil J
    Mississauga, Ontario
    Great photos though.
  3. beeline
    North Alabama
    Good advice and nice photos. Only thing I would add is learn to hand catch. That would have saved your bacon in this circumstance.
  4. Milfodd
    Thanks. Would you mind explaining the ways of the hand catch? All those swirling props make my fingers rather nervous.
    Silvaplana likes this.
  5. Dirty Bird
    Glen Burnie, MD - USA
    Glad your bird wasn't harmed. These things are sometimes remarkably durable. Your first photo showing the Phantom Pro. There is something eminently cool looking about the Phantom. Something elegant, like I expect it to emit some R2-D2 beeps and fly off on some secret adventure. ;)
  6. lolonisadie
    Bay Area, California
    There are videos on how to catch your P3P on Youtube. You need to make sure its above your head and not windy. I also learned some lessons and start heading back at 40% battery instead of 30% to make sure it makes it home before battery runs out.
  7. MrMcfly
    Melbourne, FL
    Put the Phantom about 5-6 feet above the ground in a hover. Then walk up and firmly grab the landing skid on a leg with your right hand,
    then without moving, push/hold down on the throttle with your left hand to shut down the motors. If you try to move your catching hand
    before you kill the motors, the Phantom 3 will fight you to keep its position. The landing gear legs are sturdy, and can support the drone's
    weight. I've done this at the beach once so far, and it wasn't really scary at all.
    I fly with a lanyard on the controller which helps a lot. Prop guards might lessen the worry of the props.... the bird is so stable at hover,
    it's easy enough to grab.
    Stinch, bluer101 and ObiDon like this.
  8. jclenik
    Amen Brother! Thanks for sharing
  9. bluer101
    When it's windy that what I do. No reason to risk a tip over on landing.
  10. RedHotPoker
    Edmonton Alberta
    Descend slow, touch down, and left stick all the way, straight back & down. Motors shut off. Why are you guys tipping over, upon landing your drones? I have never hand caught my Phantom, nor have I even come close to tipping over after landing. Must be the terrain, you frequent that necitates this behaviour. Personally I feel it's dangerous and unnecessary... Each to thier own, devices...
    RedHotPoker
  11. MrMcfly
    Melbourne, FL
    I chose NOT to land my P3 on a sandy beach. I tried the grab technique. It works well. I do not use it exclusively. My LZ
    that day was overcome by parked cars. I fully admit an oversight on my part, BUT on the beach, or on the highway were
    the two choices. Kicking up loose sand from prop wash seemed a greater evil. I've also gone swimming right after I ate...
    ...I just live on the edge. ;)
  12. RedHotPoker
    Edmonton Alberta
    Yeah, but have you tried swimming after eating a double order of octopus, squid and giant prawns? ;-)
    I bet you will do belly flops too, eh? Hahaha
    Try the sushi?
    RedHotPoker
    MrMcfly likes this.
  13. Justgregg
    Denver Colorado
    Learn how to hand catch ur p3.
  14. MrMcfly
    Melbourne, FL
    NO! But I did stay at a Holiday Inn Express once.... heh... heh... heh
  15. RedHotPoker
    Edmonton Alberta
    Not me, I'm down the street, in hot plate heaven, at the "Green Hotel"
    Try the cheese whiz?
    RedHotPoker
Similar Threads - Live Another Forum Date
Stream live video feed to another device Phantom 4 Pro Discussion Jan 6, 2017
Facebook Live - How to Switch to Another FB Account Pro/Adv Discussion Jul 16, 2016
Another Prison Delivery General Discussion Oct 27, 2015
Crashed my P3A but it lives to fly another day Pro/Adv Discussion Aug 26, 2015
Facebook livestreaming CrystalSky Monitors Today at 7:48 AM
