When I power up the phantom the gimbal stays down and when I move the tilt for the gimbal, this one won't go up. Now I have the upgraded version
Eltrochaphantom said:When I power up the phantom the gimbal stays down and when I move the tilt for the gimbal, this one won't go up. Now I have the upgraded version
Mako79 said:Eltrochaphantom said:When I power up the phantom the gimbal stays down and when I move the tilt for the gimbal, this one won't go up. Now I have the upgraded version
How are you Eltro? What upgrade did you get?
Can you check in the Phantom assist on the range of the X1 tilt dial. If it max up and down then good. If not, calibrate.
Can you check in the Phantom assist > Advanced > Gimbal > Set gains to 10, Horizontal to 0 and vertical to 0.
Let us know.
Eltrochaphantom said:Mako79 said:Eltrochaphantom said:When I power up the phantom the gimbal stays down and when I move the tilt for the gimbal, this one won't go up. Now I have the upgraded version
Let us know.
Hey mako79. Very well thanks
I went and looked for updates, nothing there I can't remember the number. I have the upgraded controller. I calibrated x1 and it does max up and then down. I set the values to what you said but no luck.
My problem is that it is all perfect until I try to move the gimbal dial. The gimbal does move smoothly but when I let go the dial the gimbal goes back to its original position which is just below the centre.
Fede
Eltrochaphantom said:Thanks a lot guys
