Little camera help, please !!
Discussion in 'Standard/4k Discussion' started by kissmyace, May 17, 2016.
  1. kissmyace
    First post! P3 standard. I'm having trouble getting pics off my camera, unless I remove the card. What is the proper procedure for doing this, or is something wrong. I would like to just use the USB on the camera. Thx
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It's easiest (and fastest) to remove the memory card from the Phantom, insert it into a memory card reader (I like this one), and insert the memory card reader into your computer.
  3. kissmyace
    That's what I do. The card is tricky to put in, if you're not careful
  4. RodPad
    Pacific,NorthWet, 97031
    I you You are hooking the USB to the Camera? Not the Phantom, I don't like popping or messing with that small card.
    #4 RodPad, May 17, 2016
  5. kissmyace
    I've had the card miss the slot & go all the way in the camera. It's a pain to get it out. I hook up to the USB on camera, but it doesn't do anything
  6. RodPad
    Should show up on your PC as a removable drive, you have to have the Phantom on and nothing holding the gimbal.
  7. kissmyace
    That's what I've tried,, but doesn't work for me
  8. tberton
    The east way is to put your USB from pc to the micro connector on the camera
    gimble,
  9. firestars
    Try another use USB port.
  10. RodPad
    What are you using for a computer, try another computer or cable?
  11. 66Fury
    South Texas
    Capt Obvious here...make sure card goes in with the BACK of the card facing FRONT of camera...it WILL go in backwards, won't read and a pain to remove...I did it first go round.
    gvsukids likes this.
  12. kissmyace
    I got it in right. I've missed it & it is a pain to get out a again
  13. gvsukids
    You also have to power up the bird
  14. MTR-Aerial
    Correct, to get the pictures off the unit while the SD card is still in the unit. You must connect micro usb cable to gimbal base and to computer. Power up unit and it will populate on the computer.
Similar Threads - Little camera help Forum Date
Professional Camera has very little movement after updates Phantom 3 Help Apr 30, 2017
little gold clips for antennas coming from camera area black and grey wires Standard/4k Discussion Dec 28, 2016
Opinion: Little spot on the p3a Camera lens Pro/Adv Discussion Jan 17, 2016
Possible Camera Range Improvement..just a little experiment. Phantom 2 Vision Discussion Nov 9, 2013
DJI Phantom 3 took a little swim General Discussion Sunday at 4:26 PM
