I keep getting aircraft requesting to go home. Even when it is close with 100% signal. I hit ok and it comes right back. Anyway to stop it
I thought you didnt need a signal to use Litchi. In other words I thought you could set your bird up to fly out of your range and it would complete the mission even if you lost your video and control signal. DO you need to turn off smart RTH in the DJI Go app first? Or I am wrong ?Smart RTH setting gets activated when battery goes low. Also if you are in a high interference area, weak signal or no signal may trigger RTH
Litchi just updated like 2-3 days ago, now the top and default mode is FPV (manual flying), it used to be waypoint mode at the top, if you have RTH on signal loss selected in DJIgo, then Litchi will RTH on signal loss in FPV mode as it's a manual flight and has no mission to continue.
Understanding that litchi has its own settings for signal loss, if I'm flying a mission with waypoints and it hasn't completed but is out of the range of the controller, how do you get it to finish the mission?Litchi has it's own settings for signal loss in manual flying, you can choose from. Hover, Landing, or Return To Home.
Put it in "S" mode and that kills the mission.You should be able to fly normally at this point and land it yourself.I was expecting it to continue mission once disconnected, was at a distance of roughly 9000 feet when it disconnected and started return to home. The other problem was, that I could not cancel return to home. It came home and landed just fine, but I couldn't take back over control of the bird.
Here is a question I hope someone has the answer to .......
I had a mission on Litchi set to go about 3.5 miles. I had someone on the other end of the mission to see if the bird made it that far and was in contact by phone with them. It did not and I had a stopwatch going to see just how long my bird was in the air. It got back to me with about 23 percent battery and about 21 min of flight time.
I could have the mission completed if it didnt auto RTH once the floating yellow RTH icon was initiated. My Low battery warning is at 20 percent so I know it didnt RTH because of this.
So , can you configure the app not to RTH automatically when that (half way point icon) is reached ?
This will auto land at this point? I guess you better have RC control , or else a huge emergency landing zone.WARNING: This defeats the Battery RTH safety! Your bird will fly on until 10% battery then auto-land. If you have RC control you can hold her aloft from 10% down to 0% while you manually fly her back. This makes learning your bird & battery limits critical.
