Correct. For this reason ensure that your last waypoint is close to where you will be (normally close to the waypoint 1). Also make sure your 'end of mission' action is in line with the possible consequences of a lost connection.Just a question about iOS Litchi. I am thinking to get the Litchi for my Phantom 3 pro. My question is, would the aircraft finish its
programmed mission even it is disconnected from the controller?
Tkeefe-Sorry didn't mean to stepped on your post topic. I just like to refer my first and second attempt in using the Litchi with my iOS system. The program will connect, it gives me all the go ahead signal to fly. but when I am at more than 50' altitude and hit Play with the mission. it gives me a prompt "Not meet requirements". I tried going up more (my mission starts at 100' and so on) close to 100' and still same prompt. Not successful for the first 2 attempts. I have made sure that I have open DJI app first with internet connection available then shutdown DJI Go and open Litchi. Litchi connects but will not start the mission when I hit start on the pre-programmed waypoints. any inputs will greatly appreciated. Thank you! BTW, I made sure also that I moved the switch to F-mode once I am on the proper altitude and before hitting the "Play" button. I'd also like to add, .. Since I was on litchi trying to fly the mission I resume in using Litchi with the flight. I have noticed though that there is NO flight tracker (or green line from home point to the aircraft), is this normal with Litchi? thanks.Help - Litchi
1. Why is Litchi not connecting to my Phantom 3/Inspire 1?
When starting the app for the first time, you will need to be connected to Internet in order to validate the app with DJI servers.
Some Internet connections may have troubles connecting to DJI servers, in such a case make sure to try a different Internet connection.
Additionally, on Android if DJI Go is your default app for the remote controller USB connection, you will need to clear the defaults for DJI Go (Settings -> Apps -> DJI Go -> Clear Defaults).
Thank you BV-SkyOne..AquArius4058,
With the release of the new version today I did not see a fix for this issue, thus I have submitted a email to Litchi with all the facts I have collect. I will copy you with any reply worthy of the effort.
Cheers
I downloaded litchi today onto my Verizon tablet. When I try to connect, the status bar says "signal lost". Does anyone know what is going on?
I went outside and it won't connect to satalites or anything.
