Litchi WP mission error - damping check failed
Discussion in 'General Discussion' started by CRF319, Jul 29, 2016.
  1. CRF319
    I flew two WP missions Wednesday afternoon with no issues.
    Last night I drew a quick mission on my Shield K1 with the pencil icon to show some friends. Launched my Standard, flipped to F-mode and hit play. Got this error -
    Failed to upload the mission (reason: The damping check is failed).
    Anyone else have this or know what damping check is?
  2. bbfpv
    Long Island, NY
    PM the developer @Kaehn or email Litchi support support@flylitchi.com
    CRF319 likes this.
  3. ryantrax
    Xenia, Ohio
    Usually when you get this it's too many points in the path (or too many points too close together). Try using individual points instead of drawing with the pencil.
    CRF319 likes this.
  4. CRF319
    Thanks, I have emailed support, will report back when I get a reply.
  5. CRF319
    I will try that tonight but I will not be at the same location.
  6. Pharm
  7. CRF319
    Thanks for digging that up, I did a search earlier with the Phantom Pilots app and didn't get any results.
    Yes, latest version 3.6.5.
    Litchi support emailed me back, here's the (same) reply -
    "Hi,
    Are you using 100% as default curve size? If you are, try to reduce this to 99% or less, damping check means that there is a curve size that is either too large or too small (likely too large)."
    I can't recall what the curve size setting was last night.
    I will the check mission settings later this afternoon, I'm at work now and my tablet is at home.
Similar Threads - Litchi mission error Forum Date
Please, any thougths: Litchi WP mission upload too often ends with "Timeout" error... Control (Go, Litchi, etc..) Jun 16, 2017
Litchi mission through the power lines - pilot error Photos and Video Mar 8, 2017
Should I try and correct for Litchi GPS errors....or just re fly mission? Control (Go, Litchi, etc..) Feb 14, 2017
litchi error: failed to start the mission (reason: the mission is not initialised) Control (Go, Litchi, etc..) Nov 21, 2016
Litchi "Mission Ended" Error Control (Go, Litchi, etc..) Aug 26, 2016
