Litchi waypoint error
Discussion in 'Standard' started by Dean Ward, Apr 15, 2016.
  1. Dean Ward
    Hi. I'm new to this forum but been flying my Phantom for sometime.
    I have recently ditched the DJI Go app and I am using Litchi as I am interested in long range missions.
    I have flown a few short distance missions with Litchi no problem but I have now come across an issue that I hope someone can help me with.
    I have set a Mission in the mission hub covering 3.9miles (6.2km) but when I try to load this to the drone I get the following error " The distance between adjacent waypoints is too large" or similar. however even if I add lots more waypoint (like every 500ft) I still get the error.
    I have seen many flights on youtube with litchi where people have gone far further than this..
    I have made sure the DJI app is not in beginner mode, no range limitation and the DJI is closed whilst I have Litchi open.
    Can anyone help or explain what could be wrong.
  2. Mark The Droner
    Are you trying to fly outside the default range limit, the red ring, the 500 meters from launch? If so, change the limit to a larger number.
  3. Dean Ward
    Thanks for the reply.. I don't have the red ring, and the maximum distance option in the Dji app is disabled. So that shouldn't be an issue. I just don't get why it won't let me fly longer missions? Annoying as this is the main reason I bought it !
  4. JBG
    JBG
    Keep in mind distance between waypoints is 2km max and I think their is a 2-5m minimum, and total mission distance is 10-12km, also distance between first and last needs to be less than 2km. Also double check dji go settings on distance limit as mention before as well as litchi distance limits.
    Sent from my Nexus 6 using Tapatalk
  5. Dean Ward
    Thanks for the reply.... This could be the problem then.. So if you are saying that the distance between the first waypoint and the last can be no further than 2km that's why it's not working... What I am trying to do is over 6km. Is there any way around this?
  6. JBG
    JBG
    No way around, besides I trust litchi, but why not end your mission within eyeshot, if you ended your mission at 6km and did not designate a rth action at the last waypoint and you lost signal imagine the consequences.
  7. m0rph
    I have only 2 problems with Litchi:
    1) Incorrect route map on healthydrones.
    2) Video signal bar shows strong signal while the connection is lost i.e. no signal.
    And a one more question: can i edit Litchi`s mission log in order to read and emulate my flight in DJI Go app?
  8. Dean Ward
    My plan was to set it on the mission and drive to the location and manually land it on my arrival. There is no way I'd have signal at 6km. The signal on my p3s is crap
  9. m0rph
    Nice plan. Then just try to drive 2 km to see if it works.
  10. Clipper99
    Campbell River, BC
    I tried flying my first mission and went through exactly what the OP went through. My mission in no way was over 2km and got the same error "The distance between adjacent waypoints is too large". My waypoints were maybe about 100m apart too. Going to try again later but the lack of real documentation for this app is disappointing to say the least! I also cannot see/find a default range limit as was suggested in this thread.
  11. Mark The Droner
    How far from the first point was the last point?
    JBG likes this.
  12. JBG
    JBG
    Lack of documentation? Have you read the help files on their website, quite detailed, as far as distance I agree they aren't there as they seem to change from time to time due to dji. With that said why don't you share your mission inside the mission hub and post the link here so we can see what you might be doing incorrectly.
  13. Mark The Droner
Similar Threads - Litchi waypoint error Forum Date
What happens if compass error happens in litchi waypoint? General Discussion Oct 25, 2016
Bizarre Litchi "drift" behaviour after final waypoint Control (Go, Litchi, etc..) Sunday at 9:12 PM
Litchi Waypoint Mission DAT File Control (Go, Litchi, etc..) Dec 15, 2017
Litchi waypoints not recognizing/saving new POI General Discussion Dec 7, 2017
Christmas Lights w/ LITCHI WayPoint (Day & Night) Photos and Video Dec 7, 2017
