Litchi very bad range
Discussion in 'Standard/4k Discussion' started by Darwish, Jul 8, 2016.
  1. Darwish
    Hi, i have an P3S and in litchi i only Get about a 100 meters distance and height.
  2. Ryan Nagy
    Pittsburgh PA
    I was really thinking about downloading that app does anybody else have any opinions and experiences I also have the Standard is the Litchi app worth it for the standard?
  3. KennyJr
    Johnstown, PA
    Quite a few here love the app. The question is, does the DJI Go app do every thing you need? For me I can't justify $25 dollars for way points which is a feature I don't use. I prefer to control the flight manually. The only feature I've used in GO is course lock when I was letting my wife use it.
    If you want to set way points without first flying them then Litchi is the way to go.
  4. With The Birds
    Australia
    How far do you get with the GO App?
  5. Darwish
    Atleast a lot more, i did a test for about a week ago. I got 850 m With DJI go and 300 m With Litchi. And now i only Get to 50 meters distance and 100 meters height With litchi.
  6. WayneMHK
    Manhattan, KS USA
    Personally, I find it a little hard to believe that the app makes a lick of difference in range. When someone wants more range, do they upgrade the software or the hardware? Just sayin'
    MasterBlaster likes this.
  7. KennyJr
    Johnstown, PA
    I'm not familiar with the settings in Litchi, does the Litchi app have a setting to limit range/altitude like the beginner mode in Go.
    It is also possible I suppose that Litchi uses a different WiFi channel which may or may not have an effect on range. I know for my home WiFi network I get better coverage depending on the channel I use. Can you manually select channels? If so try a different channel. If the are a lot of WiFi networks in the area use an app like WiFi Analyzer to find a channel that isn't used it the area and see if the range improves.
    Just grasping at straws here.
  8. Darwish
    It Looks like only the video signal has problems, i can still use the rc to control the ac.
  9. Darwish
    Yes i can change channels, its on auto.
  10. Darwish
    I downloader wifi analyzer, how do i find the channels that isnt used here?
  11. KennyJr
    Johnstown, PA
    I have WiFi Analyzer by Kevin Yuan. The very first screen shows which channels are in use, the network name, and relative signal strengths. If you can manually set the channel in Litchi, use one of the unused channels.
  12. ccbdav
    I have anecdotally experienced reduced video range with Litchi, as well. Particularly in FPV mode. This is while flying from the same location in the country with no other wifi networks in range and under similar weather conditions. It may just be a spot of bad luck when it happens, but I have simply reverted to using Go for longer distance flights (over 250-500m) just to be safe. I still love and use Litchi for missions, panos, and FPV---just suggesting one option.
    For what it's worth, there is a thread somewhere with a quote from a Litchi dev stating the channel-switching feature does not work anymore (I think due to a recent firmware change by DJI a couple of versions ago). I'll try to find the link and post it here for you.
    #12 ccbdav, Jul 9, 2016
  13. Darwish
    Oh ok:) Im using DJI Go now too.
  14. toegema
    If the video is an issue, are you sure you don't have an underspecked tablet?
    I used DJI GO on an older iPad mini 2, which worked ok. But with Lichi the video got all chopped up. Had nothing to do with the actual range. I swapped with the newest iPad air and both apps performed really well. Or do you actually lose Video connection?
  15. WilliamM
    Lancaster, Pa.
    "The only feature I've used in GO is course lock when I was letting my wife use it."
    You let your wife touch your drone? lol That was funny.
  16. WilliamM
    Lancaster, Pa.
    That's what I thought too. Just downloaded Litchi so haven't tested it too much yet. But today I went to a area I've been a few times before, and went the same route. With Go I made it to 845m and stopped at that point, was going over a RR yard and didn't want to go any further. Today with Litchi I could only make it to 700m (just short of the RR yard) before the auto RTH, tried three times. Two times were at 700m the other even less. Going back maybe tomorrow and try the same route with GO.
  17. WilliamM
    Lancaster, Pa.
    There's a option under camera setting that says "Transmission channel" with choice of (0 to 31 and auto) isn't wifi only channels 1 to 14. But since it says "Transmission" maybe that's the RC it's talking about, not the wifi. But it's under the camera settings??
    #17 WilliamM, Jul 9, 2016
  18. Darwish
    Its the video signal, i use an IPhone 6.
  19. Darwish
    You click the setting tab at the right up corner, you can find the channels there.
  20. Darwish
    Ok, please update us:)
Similar Threads - Litchi very bad Forum Date
Very Disconcerting During Litchi Waypoint Mission Control (Go, Litchi, etc..) Mar 23, 2017
Very first attempt of a 360° Panorama using Litchi.. Pro/Adv Discussion Dec 14, 2016
Litchi App -> Gimbal dial very slow Pro/Adv Discussion Dec 2, 2016
Very last litchi question I promise General Discussion Oct 24, 2016
Litchi problem!, Every time the drone reaches a WP it turns around it selves. (360) Phantom 4 Help Oct 3, 2016
