litchi on my phantom 4
hi all from Australia
I have just purchased a phantom 4 and would like to fly it with the litchi app
I want to fly a rectangle ,four waypoints with no poi and have the drone facing straight ahead to each waypoint
I then want the drone to stop at that waypoint for three seconds
then turn towards the next waypoint before it leaves that point and go straight to the next waypoint
doing this at all waypoints
is this possible
11-45 at night here
cheers rasa
Yes it is. The easiest way to do it is on the website Mission Hub - Litchi you can set a bunch of actions at each waypoint including "Stay For" and input the number of seconds.
YES! Litchi can do that and more! It's all done at each Waypoint. On mine, I will go into the Mission Hub and layout the planned route on a small scale at a low height. In each Waypoint I would tedd the drone to rotate whatever number of degrees necessary and program the time to wait. After programming all waypoints I would fly that mission and if all looked good then keep the Waypoint data but adjust the altitude and dray the waypoints to the desired spot on the map. It should fly perfectly.
Litchi can't be beat in my opinion! Love the Waypoint feature.
Jim
WA5TEF
