Litchi Mission - POI's were ignored
Hey Guys,
I set up a Litchi mission last night, and took her out to the park to give it a test run this morning (this is my 2nd mission ever FYI. I set up a small test mission and it worked well, so this is my second attempt).
It flew the route i plotted, but did not seem to focus on any of the waypoints.
Does anyone have any idea what i may have done wrong? Im going to review the mission settings again, but any tips would be helpful.
It shows the correct headings on the map, but for some reason it did not turn to point to the waypoints.
The video is uploading, and once its finished i will post it here for you to see.
You have to hitting the settings and make sure it's set to focus on poi
Reactions: Suhail78
I thought that at first, but when i was double and triple checking the waypoint settings i made sure that the ones i wanted to focus on POI were.
Check in the main settings, not for each waypoint
So i THINK i know why the POIs didnt work.
Apparently, the heading mode should be set to custom. Can anyone confirm this??
That is correct. In addition, be aware that if you lose contact/connection with the controller, the mission will continue as planned but will not focus on the POIs. The camera angle will remain at the last angle it was on before losing connection. This is not a Litchi error. The DJI SDK (Software Development Kit) does not allow gimbal control (even automated) without connection to the controller.
Reactions: Suhail78
Hey thanks for confirming that for me, no connection loss, it was a short 1 mile mission around a small park, but didn't realize i had the heading settings on manual until i got back and watched the video! will make the necessary adjustments and give it another test run maybe later this afternoon. Not too bad for my 2nd litchi mission tho!
1D10T Operator error will get you every time! ha!
Hope it goes well today. Litchi is a lot of fun!
Reactions: Suhail78
Thanks Man. Really having fun with Litchi.
i'll update this post later on and let u know how it went, and hopefully i'll have a new video to post as well!
The one mission I ran that went beyond my remote connection did continue to aim at the poi's between wp's. I did have camera tilt on manual, which would not give me back control of tilt until back in range, but it still caught what I was after.
Reactions: Suhail78
Made the adjustments, changed the headings mode to custom and it worked!
Heres the video! Thanks for the advice guys! Cant wait to plan and fly many more litchi missions!!
Not bad for my second attempt with Litchi, its nothing special, but its a start!
And still fun!
Reactions: Suhail78
jrl
