Litchi will upload the data for the entire mission prior to takeoff so the quad does not need a connection to the controler while proforming the mission.
Yes it will continue as the mission is loaded on the drone when you upload it from the device you are using. From memory, you may lose some of your camera and gimbal actions, but the mission will continue regardless.
I heard different. The altitude will stay the same as the last way point when connection is lost. Would love for you to let us know esp with the camera too
Both heading and altitude will remain under programmed control if the RC signal is lost. Gimbal elevation and aircraft speed will remain at the same values as where RC contact was lost.
