Litchi help please
Can someone please help me? I have tried probably about 20 different Test missions using Litchi waypoint with point of interest. I have the settings set to custom on heading mode I have focused everything to point of interest, with the point of interest being 3 feet. Curves are turned off, using straight line, but the camera never moves it always looks straight and never auto turns to look at point of interest. What am I doing wrong? I Will try to attach a short video to show my Settings.
After setting each desired way point to lock on the POI, mission settings "Heading mode" must be: way point defined.
I figured out my issue. Apparently for the gimbal pitch to work at a point of interest the aircraft must be in range with the controller. In my opinion that really is a bummer. The whole reason why I set a mission is because I fly the drone out of range in “auto pilot” which obviously means it will not gimbal pitch to the point of interest :(
You're right, it should run outside the range of the controller. I think your issue may lie somewhere in your settings. Check-out this video and compare to what you're doing now.
Click on a waypoint... Then scroll down to you get to the litchi arrow in a compass... See how it's facing the same direction as the one on the mission
Turn it around in the compass, and waypoint arrow will turn around too
Here is how I have all my settings
hirehackers
