Litchi for iOS adds Orbit...
Discussion in 'Pro/Adv Discussion' started by Phantazmk, Feb 12, 2016.
  1. Phantazmk
    Hers the change log;
    Added Orbit Flight Mode
    Misc Ui improvements and bug fixes
    Nice update
  2. Waxings
    I use my iPadPro for mission planning and the update keeps crashing? Worked great before.
  3. Phantazmk
    I find if you delete the App and then download the new update it fixes the issue. I've had to do this with the GO app as in the past, as well
  4. Pete Leare
    Windham NH
    I agree, whenever there is an app update available (not just this one, but any app) I always delete the existing one first then go to the App Store and download the new one. I NEVER hit update. I flew with the new litchi app this morning on IOS with no problems whatsoever
  5. adfischer
    Tennessee
    If you are using the new Orbit mode keep this in mind:
    From Litchi.com:
    Failsafe
    If signal is lost between the aircraft and the remote controller, the aircraft will continue the Orbit session until it reaches the critical battery level (can be set in DJI Go). It will then land in place automatically, even if your failsafe is Return to Home.
    JBG, Phantazmk and sonof40 like this.
  6. CCDD
    US
    Good to know!!
  7. Waxings
    I did this and it is still crashing. I don't use the pro for flying but it is nice for flight planing.
  8. Erroll
    South Africa
    I did the same, but the app only re-installs halfway and then the installation just hangs??
  9. Phantazmk
    Hmmmm, you can try this. Hold Down the Home Button and the Power Button for about 5 sec. Your I device will shut off. Restart and try the install again. This clears out the cache file and should help. Also make sure your iDevice is current with the latest software. iOS 9.2.1
  10. shockwave199
    Apparently there is an issue with ipad pro crashes. According to support it will be fixed in the next release.
    Phantazmk likes this.
  11. shockwave199
    A follow up rev has been released to fix the problem. Ipad pro users should be set.
  12. Phantom751874
    Wow, that's a huge bucket of fail.
  13. Erroll
    South Africa
    Cheers. I tried that but the install got stuck again halfway and just sat there for two hours, so I left it overnight, and lo and behold, it was installed this morning.
    I am now installing the patch for the pro crash, and it is just as bad.
    Both Airnest and Testflight had upgrades last night and they both installed normally, so it is not my device or connection.
  14. Skylark
    Wiltshire, UK
    Doe anyone know how to determine orientation on Litchi. There appears to be no radar screen as on the DJI Go App?
  15. Ron K
    I have to say all the programs having contradictory settings is confusing. I set thing in the Go app, then find I set again with other limitations in litchi then again in autopilot. (which over rides what and when) I think the most confusing thing so far for me since I haven't found the answer is when I set the software (go app) to IMPERIAL. It asks for flight ceiling limit and says (20~500m) [ ] Since I'm set to imperial. Is 100 in the box 100 meters or 100 ft? I assume it's meters, so I set it at 100. But I have tree's around me taller than 100ft. And really do I want it to raise to 300 ft before coming back on low battery?
  16. shockwave199
    In the go app, even though you set imperial the RTH is metric. So yeah, 91 or so meters will get you the 300' you want.
Similar Threads - Litchi iOS adds Forum Date
Litchi Missions: Android VS iOS Control (Go, Litchi, etc..) Jun 29, 2017
Litchi iOS update 1.16.0 Control (Go, Litchi, etc..) May 16, 2017
Litchi Update IOS Control (Go, Litchi, etc..) Mar 14, 2017
Litchi IOS Track/Follow. With P3 4K. Not compatible! Control (Go, Litchi, etc..) Jan 15, 2017
Litchi in iOS - No GPS Coordinates in Waypoints Pro/Adv Discussion Dec 7, 2016
