You should be able to do it on both Android and iOS by dragging the Home point on the map (while flying).On the IOS version, there is no way to set the RTH location... I've been turning on DJI Go first, and setting it before I switch over to LItchi. Is there any way to set the RTH location on the Android version? (I'm not intending to hijack your thread.)
Thanks for the input but it is not the home point I wish to set or alter it is the return to home feature in case of a signal loss etc.
That would be true if the pilot was flying waypoints.You can perform an RTH by pressing the button on your RC. I think you may want to switch it over to P Mode first.
According to the Litchi manual, once signal is lost, the aircraft continues to fly the course and then activates RTH (if you've selected that in the options).
T
