P3 Firmware Litch waypoint speed question
I notice that for each waypoint, you can select a speed or just select 'use cruising speed'. But would it cause problems if you mixed the two?
Suppose you set a fast cruising speed to get you to a certain area then you used a slower speed for a few waypoints in order to get more detailed video once you reached that area, then selected the cruising speed for the rest of the mission to get the bird back quickly, would you run into any problems?
Since it's a viable choice in the app, using as you described shouldn't be a problem.
cokersean20
