Linking GL300L to P4P v2.
Website
www.jeffreysipress.com
I know that these two units are compatible, but are not linking. Yes I've read the dozens of previous posts like this one. I want to try using a bigger screen than the '+' controller has so I hooked up an iPad mini to a GL300L. The Go4 app runs fine, but the linking message says 'linking in progress' and never does. I've restarted all three items and same message. Is there a magic trick?
UPDATE: I changed cables. Of course the cable with the DJI logo worked! Never mind......
No, this was the first time I ever hooked up a device (iPad) to a controller. A black cable came with the setup when I got it (very slightly used) but I had that DJI one as a backup.
Some cables are charge only with no data connection. They typically don't have any obvious difference in appearance. When or if you purchase more cables, make sure they say they are data as well as charge.
Reactions: JeffreyS
Pauos31
