Has been working fine with ts55823 transmitter. Now even at close range it has a lot of interference and screen rolling. Any ideas on what I need to check? Thanks
Everything is the same as it came out of the box. When it first happened I had to turn the antenna, This last time I was around a lot of Wifi transmitters here in the campground. As it is 5.8ghz they shouldn't of bothered the video feed. Will fly in another location away from all that stuff and see what happens.
Thanks for the info Jason. I fly with it off as it can interfere with the controller. all settings check as being the same. Will try a different channel when I next fly.
