LightBridge Control Issues
Discussion in 'DJI Lightbridge' started by mogermedia, Jun 27, 2014.
  1. mogermedia
    I have the LightBridge installed on my Phantom 2. I'm using a Devention DEVO-10 transmitter and for some reason the Aileron and Elevator Controls are switched. So, to go forward< I have to push the stick to the left. Also, when I push the Throttle up, the X2 goes up as well. Is the DEVO-10 a piece of crap or am I doing something wrong?
  2. admax02
    Can't you just reverse it in the assistant software?
  3. mogermedia
    Not sure I can put this into words correctly but. you can only reverse the individual controls. For example, if I push the stick forward and the Phantom goes forward, I could hit Reverse and then if I push the stick forward, the Phantom will go backward.
    However, in my case if I push the stick forward, the Phantom will go right. What I would need the assistant software to do, is essentially rotate my stick, so that the Aileron is Left/Right and the Elevator is Up/Down.
    EVEN if I did fix that somehow, that wouldn't explain why the Throttle also controls the X2 control mode. I'm starting to think that the DEVO-10 is just cheap and that DJI made a mistake putting it on the LightBridge Compatibility list.
  4. sar104
    Los Alamos, NM.
    Have you done a full calibration in the Lightbridge Assistant, which also allows you to map channels?
  5. mogermedia
    That sounds like it might fix my problem. The only issue with that is that we are all Mac here at the office. :(
  6. sar104
    Los Alamos, NM.
    Me too, but there are many occasions when Windows is necessary. I just run a virtual Windows machine on one of my Macs.
  7. mogermedia
    We have an old XP machine around here. I guess I'll try that lol
  8. mogermedia
    Ok I have LightBridge Assistant running. Any tips on what I'm supposed to do with it. I have my transmitter plugged into the lightbridge and the lightbridge plugged into the computer, but nothing seems to be happening between them. Is there a certain order that those things need to happen? Thanks
  9. mogermedia
    Good News! It's working now. If anyone else has the same problem as me just use the Lightbridge Assistant Software. I was using Windows XP and when you install the driver it says it does not pass the Windows Logo Test, but you can just ignore it. It works fine on XP. Also, keep in mind that after you remap the channels in the Assistant Software, you need to restart your Ligthbridge Ground Station or else it won't connect to the Air Station. Thanks for all the help guys! :) You saved our Phantom
Similar Threads - LightBridge Control Issues Forum Date
Lightbridge vs WIFI for control Pro/Adv Discussion May 9, 2016
Phantom 3 Adv/Pro remote controller - transmitter (Lightbridge) Classifieds Mar 21, 2016
p3p, p3a, and lightbridge controller Pro/Adv Discussion Jan 12, 2016
Limits on Phantom 3 Lightbridge control and FPV Pro/Adv Discussion Jul 4, 2015
Lightbridge and control unit Pro/Adv Discussion Jul 1, 2015
