Ok so I've had a P2 (in NAZA mode) and H3-2D since it came out. Have gotten along pretty good (other than one battery going bad). No major wrecks.
P2 already on 3.04 software (although P2 assistant software shows 3.4? wtf? -- reinstalled P2 assistant and then its 3.04 again)
Yesterday opened it up to upgrade to H3-3D and Lightbridge (never had FPV before).
Install went smooth and exactly like the DJI video
Fired it up, updated software for ground end, air end, and h3-3d.
Again, process went good.
Hook up ground end to my Nexus 7 tablet and T8FG trainer port.
Video works great, but no control with the sticks on the T8FG, and it appears stuck in failsafe.
So messed around with it awhile, did the cal in Lightbridge assistant, etc.
Video continues to work great, but no other control.
So, I unplug the T8FG from the trainer port, P2 starts flashing yellow, so I know it sees the controller.
Dealer suggested putting back to stock and making sure everything works there.
So, that's what I do, even leave the gimbal completely unhooked too since it's new as well.
Now, every time the P2 is turned on I get 3 quick red lights, which I guess indicates sensor out of range.
Where do I go from here?
Was careful with the compass, no magnentic screwdriver, and P2 even let me calibrate it because my S1 and S2 switches work. Still no control sticks though (keep in mind back to all stock, even stock controller).
Tried basic IMU cal. Worked fine.
Did advanced IMU cal, it tells me temperature of MC is too high.
Turned off, tried again, temp message comes up again right away.
So now I'm at a loss. I realize it's complicated, but where do I go next?
Back to DJI for warranty and wait 4 weeks+?
