LiFePo 2s in transmitter controller tx ??
Discussion in 'General Discussion' started by bds2710, Aug 6, 2014.
  1. bds2710
    NSW Australia
    Has any body done this mod ? LiFePo4 2s in transmitter controller tx ?? As it is a constant 6.6 v and just seeing if it will work
    Looking at the hobbyking nano tech one 2100mah 6.6 transmitter pack
    Cheers in advanced
  2. CactusJackSlade
    I usually like to move to rechargeables of some kind (Li-Ion preferred) but I'm getting 40+ flights over a 4 month period with just alkalines.... so to me it's not worth it on the STOCK transmitter.
    Just my 2 cents
  3. HarryT
    Warrington, UK
    Just to clarify - are you talking about the DJI transmitter that you fly the Phantom with, or a video transmitter mounted on the Phantom itself?
    It it's the former, then normal NiMH rechargeables work absolutely fine in it. There seems no reason to look for anything more sophisticated.
  4. bds2710
    NSW Australia
    For the transmitter , just want a set that would give me max constant power rather the slowly dropping down as the more I fly as trying to fly further away with the help of fpvlr antennas and want everything to be working at its best and most powerful it can
  5. N017RW
    Palm Beach Co.- FL
    There is no reduction in power, range, etc. as the batteries discharge.
    The Tx, like most modern electronics, contains internal [voltage] regulation which assures consistent performance until the 'low batt' alarm level is reached.
    At that point the cells should be replaced.
Similar Threads - LiFePo transmitter controller Forum Date
Lifepo4 6.6 volt charge settings help General Discussion Jun 30, 2014
How to charge lifepo4 batteries General Discussion Jun 29, 2014
12V LiFePo battery for flight? General Discussion Apr 27, 2013
Multible FPV goggle on 1 transmitter Phantom 4 Help Jul 28, 2017
Standard Can I link 2 transmitters Phantom 3 Help Jul 27, 2017
