life time of new motors
Discussion in 'Pro/Adv Discussion' started by drones2sky, Jan 9, 2016.
  1. drones2sky
    Hi guys,
    Does anyone knows what is the life span of the new motors on p3a/p?
    Does DJI mention anything about this?
    Thanx!!!!
  2. N017RW
    Palm Beach Co.- FL
    BLDC motors have only bearings that move and to wear.
    Their lifetime is hundreds of hours.
  3. Techcop50
    Aiken, SC, USA
    Bought my P3S in September, just now noticed a bad motor, right rear, with just 13 hrs on the bird.
    It's flopping around on the stator like a fish, feels like the bearing is shot. New style motors, btw.
    Anyone else had this issue?
  4. wooglin
    Wow that's not very long. If any of mine start to wear I will probably solder in a pair of connects that way the body does not have to be taken apart to replace them.
  5. Techcop50
    Aiken, SC, USA
    Yeah, I'm having the same thoughts...
  6. Dirty Bird
    Glen Burnie, MD - USA
    As with anything there will be duds but in general I would expect the motors to last into the hundreds of hours.
  7. Techcop50
    Aiken, SC, USA
    Yeah the other three seem perfect, no play whatsoever, and they turn smooth and free.
    The scary part is I had just flown out 3000+ feet, 390 feet above the woods, just noticed it sounded a bit clunky upon return. Could've dropped at any time. From now on, I'll check them all before each flight, this made a believer our of me!
    Live and learn.
  8. Techcop50
    Aiken, SC, USA
    4/3/2016 - Just swapped out my second bad motor, another CW one, diagonally across from the first. This one had about 24 hrs. flight time on it.
    Nothin' is as handy as a spare tire, when you need it!
  9. t2adze
    How can you detect the bad motor?
  10. With The Birds
    Australia
    In all probability you will be enticed by a new model offering or suffer a non motor related loss before the motor bearings give way. Esp if you run balanced props and avoid hedge trimming and inverted landings.
  11. Techcop50
    Aiken, SC, USA
    I do balance my props, but i'll be the first to admit my props have occasionally see greenery. But this last motor failure was not the result of that, I have not hit anything other than air for months.
    As far as detecting it goes, it was first noticeable to me as a slight wobble when changing altitude. Upon closer inspection, there was cyclic ringing noise. The final test is to: Remove the battery, wiggle the props up and down and check (compare them) for play, and any thumping or clicking noise.
  12. With The Birds
    Australia
    There are no guarantees however my view is if they pass the manual wobble and end float test prior to a flight they aren't likely to catastrophically fail within the next 18 minutes....
    Techcop50 likes this.
Similar Threads - life motors Forum Date
P4P Motors lifespan/MTBF? Phantom 4 Pro Discussion Jul 5, 2017
Lifespan of motors? Phantom 2 Vision Discussion Mar 2, 2015
P4 battery life expectancies Phantom 4 Help Aug 11, 2017
Life Cycles-Average#-Per P3P Battery? Pro/Adv Discussion Aug 2, 2017
The Good Life;) Photos and Video Aug 1, 2017
