Leveling camera/adjusting gimble
Springfield, MO
After a surprise encounter with a light pole, the vertical camera support for the camera on the gimbal is slightly bent. Everything works perfectly except now the videos/photos are about 4 or 5 degrees off level. Does anyone know if it's possible to re-calibrate the gimbal for the horizontal setting to adjust for the "new" level horizon? It just needs a tweak.
I have just had the same issue with mine (hit a tree).
As I had never had mine connected to a pc, I downloaded all the drivers/software etc and did every calibration in there. the last calibration was on the gimble, it said it didn't need it but I did it and it worked.
the flat plate (top section of gimble) which is fixed to the phantom body is slightly bent in one corner on mine, I suspect this was throwing it out, calibrating it seems to have fixed it.
hope that helps.
