When I take off with my FC40 it goes straight up but the tail goes up first. How do I cure this? I have to give it 100% on take off.
sherpa said:When I take off with my FC40 it goes straight up but the tail goes up first. How do I cure this? I have to give it 100% on take off.
1/4" plastic spacers under receiver and main board. Cut 6 wavy battery guides out of tray. Cut wire slots in sides of battery door and connect batteries outside door. Cut battery opening to almost same size as door. Two stock batteries will then fit nicely.sherpa said:Doh! I see 18 min. now! How in the world do you get two stock batteries inside?
Ramz said:I run 2 stock batteries inside with stock battery door closed. It has the center of gravity a little far forward but it flies good, 18 minutes. The front on it seems to sag as well and can hear the front props turning faster. I have a couple sets of 9" props on the way. Wondering what would happen If I put 9's on front and 8's on rear. I'll try it and let you know, hopefully not crash!
Ramz said:OK I did the test, Phantom flies fine with 9" on front and 8" on rear (front being the side marked as such with stickers). In fact I cant tell any difference in handling with the mismatch. The reason I tested this was curiosity had me wondering if the front would still sag during take off and the answer is, yes it does exactly the same. Flight time remained approximately the same as well.
