marcus_canada said:My Larger Machine is held aloft by the DJI Wookong M unit & 5000mah 4S power. Control by Futaba T8. Servo operated active gimbal (Soon to be replaced with Brushless Arris unit) and Predator V2 FPV setup.
DeweyAXD said:marcus_canada said:My Larger Machine is held aloft by the DJI Wookong M unit & 5000mah 4S power. Control by Futaba T8. Servo operated active gimbal (Soon to be replaced with Brushless Arris unit) and Predator V2 FPV setup.
Nice... what kind of flight time does that beasty give you?
lightfighter363 said:@GrumpyTy, where did you get that vinyl?
GrumpyTy said:lightfighter363 said:@GrumpyTy, where did you get that vinyl?
It's a local hobby shop here in Ca. Called Pacific Coast Hobbies. It's a actual wrap that they make specifically for the phantom and controller. They run around $19.99. and they make a variety of colors and patterns. I've seen a couple on eBay. You may want to check. Hope this helps.
