Less Crack Complaints
Discussion in 'Pro/Adv Discussion' started by snowghost, Jul 20, 2015.
  1. snowghost
    SoCal, USA
    Just an observation, but it seemed like every morning there were new reports. That seems to have quieted down. Maybe that's a good thing.
    I'm on 51 flights with no cracks and hoping it stays that way.
  2. rmfa
    I put epoxy on mine and have not looked back...
  3. storrowdrive
    Boston Massachusetts
  4. snerd
    Oklahoma
    I'm still on the rubber band method.
    [​IMG]
    [​IMG]
    [​IMG]
    ETA: the black stuff on my bird is from peeling off a light strip I had on there. Haven't gotten around to cleaning her up yet.
  5. snowghost
    SoCal, USA
    Are those marks from a crash?
  6. snerd
    Oklahoma
    No crashes, no near-misses, nothing. Just great flying on my P3P on software 1.2.6 with VPS turned off. See note above, under last pic, for the black stuff explanation.
    snowghost likes this.
  7. FredSheldon
    The Woodlands, Texas
    I suspect it's because DJI stepped up to the plate and offered to repair or replace all units that had cracks. All you had to do is give them a call. Either that or apply one of several suggested fixes and move on.
    ScottyT likes this.
  8. nhoover
    Los Gatos, California
    I used Bondic on mine - one small crack outside of the screw on one of the read arms.
  9. skyhighdiver
    South Dakota
    well sent mine P3a with 18 flighs on it back to Amazon on day 28 of there warrenty. It had cracks as far as even a hole on both back arms.
    I have no doubt the mounting hubs were broke off if I were to open. Love Amazon boxed up Friday and sent back got notice today my new one will be here on Tue Now that's customer service DJI TAKE NOTE:eek:
    Bigdz and silverstoned83 like this.
  10. ScottyT
    Melbourne, Australia
    They're still being reported on DJIs forum. But yes I think the more vocal people have just given up, or patched it themselves and moved on.
  11. Jbundy63
    Way back I zip tied the arms, balanced the props and now have over 100 flights without any issues. Hoping to stay that way!
    bobmyers likes this.
  12. skyhighdiver
    South Dakota
    I will be zipping my new one as well!
    also hope DJI Checks for this with My P3P they have for gimbal vibration before sending it back
    Jbundy63 likes this.
  13. BuckRogers
    Yep, I fixed mine and its stronger than factory or a replacement shell with Bondic. I'm not buying into their 8 weeks BS. They already have a bad rep for CS. I could of spent more money on their products but now, no thanks. One P3 will have to do
  14. envisionabove
    Tim in San Diego
    First Gen Batch ( I like that First Gen P3P :) )
    I noticed some screws deeper than others in the same location.
    Loosened all and snugged them down nothing yet since.
    I do have one crack. Black Hub Arm. This was before unsnugging.
    #14 envisionabove, Jul 20, 2015
  15. bighi
    Gibraltar/Austria/Italy
    I super glued mine and it's holding.
  16. Bigdz
    Ca
    Done what everyone mentioned...holding together well. Arms are stronger... 1 mile range test today...
    Cracks have seem to stopped for the time being
  17. YolevonALLin
    Why not zip ties? Rubber bands would appear to be far less restrictive and allow for movement... Hence the rubber part of their name. Don't you need something that holds the pieces together flush and tight? If I'm wrong, I apologize.
    Sent from my SM-G920V using Tapatalk
  18. YolevonALLin
    OK, I know it must have been mentioned, but I need an expert opinion. What is the best possible prop balancer, and ALL accessories to go with it? Ie nail Polish, etc? So people say it. Doesn't matter at all
  19. silverstoned83
    Super glued mine together as well. So far so good. I still prefer this method over the others mentioned, even though it will require much more effort to seperate the shells in the future. I want the arms to be as rigid as possible...
  20. skyhighdiver
    South Dakota
    My thought is the stiffer the better
    You don't want the ARM to flex that is the reason the holes are breaking out. The added power on a weak joint and pop
    so my 2 cents says zip tie over flex bands:D
    Jbundy63 and bobmyers like this.
Similar Threads - Less Crack Complaints Forum Date
Flying Lessons-North Dallas, TX, area? Pro/Adv Discussion Aug 3, 2017
Flying Lessons-North Dallas Area Pro/Adv Discussion Aug 3, 2017
FPV Stutters to the point of being useless Pro/Adv Discussion Jul 29, 2017
B&H: WD 2TB Wireless USB 3.0 External Hard Drive General Discussion Jul 28, 2017
Video signal is much less choppy! Quick fix! Standard/4k Discussion Jul 25, 2017
