Lens scratched
Discussion in 'Standard/4k Discussion' started by Erod707, Dec 4, 2015.
  1. Erod707
    Is there a way to fix a scratched on the lens? How much would it cost to replace the lends itself? Thanks guys
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The lens is not removable and/or replaceable. Other than buying a new camera, you might be able to send it in to DJI and get it repaired. Give them a call and see what they say.
  3. stevenc93
    A piece of very fine sand paper should do the job
  4. Jack Hurlbut
    I wouldnt recommend using sandpaper that will just make the problem worse. Even the finest sandpaper would alter the lens shape and remove the lens coating, making the lens useless.
  5. Musicman666
    Does the scratch actually show up on the footage? ..... it's the back of the lens that is critical....which thankfully you cannot scratch.
Similar Threads - Lens scratched Forum Date
Scratched lens...what's the best method to fix this stock UV filter? Pro/Adv Discussion Sep 2, 2016
Professional Front lens scratched, is it a protective cover? Phantom 3 Help Nov 3, 2015
Fixing the scratched lens of your GoPro without replacing General Discussion Jun 23, 2014
Go Pro Hero 3 scratched lens FPV (First Person View) Jun 2, 2014
Scratched my lens, possible to find spares? Phantom 2 Vision Discussion Jan 10, 2014
