- Joined
- Jan 22, 2014
- Messages
- 112
- Reaction score
- 0
Has anyone had any experience with filters for the P2V. What filters work well, what doesn't etc. Also the best place to buy filters.
Any advice gratefully received
smatty2023 said:Ok that's great thanks I did see that, but wanted something more black and white, by lens filter if necessary!!!!
AnselA said:smatty2023 said:Ok that's great thanks I did see that, but wanted something more black and white, by lens filter if necessary!!!!
In which situation do you think the use of B/W filter on Bayer sensor digital camera would be "necessary"? Or useful, at all?
I'm guessing he meant "something more specific" where it says "something more black and white"...AnselA said:smatty2023 said:Ok that's great thanks I did see that, but wanted something more black and white, by lens filter if necessary!!!!
In which situation do you think the use of B/W filter on Bayer sensor digital camera would be "nevessary"? Or useful, at all?
jimre said:I'm guessing he meant "something more specific" where it says "something more black and white"...AnselA said:smatty2023 said:Ok that's great thanks I did see that, but wanted something more black and white, by lens filter if necessary!!!!
smatty2023 said:When I said black and white I didn't mean literally, sorry for the confusion I mean a more definitive explanation of what filters gives what effects that have been tried and tested with the P2V
Pull_Up said:http://phantompilots.com/viewtopic.php?f=7&t=8615
I did a "review" of the performance of a cheap polaroid polarizer and posted a brief video clip. The shiny lens surround on the Vision causes flare and reflection against the inner surface of the CP filter - I might experiement with dulling it down with some matte black electrical tape or similar removeable system. A DIY lens hood might help with that too. I posted a short video clip which was a bit better in terms of the flaring and shows that the cheap CP certainly cuts sun glare and reflection from water surfaces and gives good contrast from clouds to sky (the clouds do "pop" out quite nicely).
I did take stills too but they suffered from this reflection problem. I don't know how more expensive CP's would fare but when we next get some sun I'll go out and try again with something covering the lens surround to make it less reflective.
Pull_Up said:I've poked him, given him what we need, including measurements, he's on the case. Matte black or other dark colour vinyl sized to fit exactly. Prototyping has begun...
AnselA said:Pull_Up said:I've poked him, given him what we need, including measurements, he's on the case. Matte black or other dark colour vinyl sized to fit exactly. Prototyping has begun...
Prototyping of what? "Vinyl"?
