led sequence 4 green rapid flashing red
Discussion in 'Phantom 2 Discussion' started by Ejazzle, May 14, 2014.
  1. Ejazzle
    Has anyone had the sequence 4 green flashes then rapid red flashing? This is after I do the compass dance. Does anyone know what this led sequence means? I let it sit for a couple minutes and still same sequence would persist.
    Thanks for any help!
  2. Madwak
    It probably means you are near an airport.
  3. Diesel31
    Long Beach, CA
    It means you have less than 7 satellites acquired.
  4. Madwak
    WRONG the four slow greens are telling you that you have enough satellites and the rapid reds are telling you that you are in a restricted zone, read the manual if you don't believe me.
  5. Ejazzle
    Whats weird is I have flown it in this same location numerous times and it has never done this before. Yes I am less than a mile away from Palm Beach International Airport
  6. Diesel31
    Long Beach, CA
    I'm not going to get into a pissing match with you. It has been in my experience that when I get the color display as described by the OP, it is due to my Phantom acquiring less than 7 satellites. Once 7 is hit, the red flashing light goes away. If it drops below 7, the red flashing light returns. I know the actual number of satellites because I can see it through my IOSD as well as my iPad when the Ground Station is enabled.
  7. Diesel31
    Long Beach, CA
    Perhaps entertain my suggestion?
  8. Uncle Meat
    Prattville Alabama
    Did you recently upgrade to the latest version of Assist by chance? If so there's your answer...
    U.M.
  9. Madwak
    Did you miss the bit where he said RAPID flashing red? Not slow flashing red (lack of satellites) Then his next post says he is within ONE mile of an INTERNATIONAL airport and you still think he's not got enough satellites, I give up :roll:
  10. ElGuano
    It's probably very difficult for anyone to interpret "4 green then rapid red"...how many red flashes? What is the sequence of the four green? What's the timing between each set? If the OP could post a short video of the flashing sequence, this could be answered instantly.
    I'm inclined to agree with those saying this is the flight restriction sequence. Especially if it just started happening recently (by recently, did it just start once you updated to version 3.0 or 3.02 firmware)?
  11. wellroundedbill
    I'm having the same issue. I wanted to make this distinction. I can definitely tell it's not the lack of satellite red flash. It's a very rapid red flash in between the green slow flashes. I've owned my about a week and no matter where I take it I always get them.
  12. nintendrone64
    Simi Valley, CA
  13. hjscm
    Bay Area CA
    well i can add that it is not a satellite issue for me and not being close to an airport. mine started doing the same thing a couple of weeks ago and i took it to my flying field which is about 35miles from an airport, because it was suggested that i was close to an airport. if you look at my other post i posted a video of the sequence. been in touch with the dealer and they have been in touch supposedly with dji. no resolution yet. i have been flying the phantoms here since they came out. i have 2 P2 non visions and only one is doing it. both on same firmware which is strange.
  14. peasap
    I'm getting this too. Got my phantom 2 yesterday. Started it up, did the compas calibration, then waited for it to acquire satellites. I got the 4 solid green and very fast flashing red. I do live within 5 miles of an air base so I'm wondering if that is it?
  15. Madwak
    Yep, that's the reason :D
Similar Threads - led sequence green Forum Date
Pre-Flight LED Sequence: 4 green, 1 rapid red? Phantom 2 Discussion May 13, 2014
strange LED light sequence P4P Phantom 4 Pro Help Jun 25, 2017
Post crash/post rebuild P2V+ LED Sequence Problem Phantom 2 Vision + Discussion Sep 18, 2014
LED sequence at start up? Phantom FC40 Discussion Jul 3, 2014
Naza v2 LED sequence question Other DJI Multi-Rotors May 17, 2014
