Launch with 4 satellites locked
Discussion in 'Phantom 2 Discussion' started by Fyod, Sep 9, 2014.
  1. Fyod
    Central EU
    I recently went to a spot where I could only lock onto 4 sats and not being familiar with Naza mode and lots of trees around, I ditched the idea.
    Now I would really like to go back to the spot and try again, but I need to know what to expect after takeoff.
    The spot is in a deep but narrow valley with tall trees around, that's probably why I can't get more satellites. Although I will be flying up so I expect that more will lock in within 3 minutes or so.
    Advice is much appreciated.
  2. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    It would be the equivilant as flying in atti mode, it'll tend to drift and not hover exactly in place.
  3. Buckaye
    Orlando
    Agreed!
  4. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Has anyone done this a number of times? I have some filming locations that won't get enough satellites before take off but will get them once above the ground level obstacles. I would like to use GPS when aloft but I have concerns about it getting a weak fix and then flying off in one direction as that fix improves and the Phantom thinking it's in the wrong place.
    Looking for real world experience with this.
  5. QYV
    QYV
    NYC
    I have on several occasions taken off without full lock and then gotten the rapid flashing lights when I'm a few meters up in the air and clear of obstacles. I've even tested RTH in those cases (at short range before flying off long range) and it basically worked... I say basically because it came pretty much back overhead where I resumed control... I never let RTH actually LAND I just take control back and catch it.
    anyway if you're concerned about where your home-point lock is, once you get up in the air and get the rapid green flashes (or see # of sats locked on FPV) you can always do the home-point reset procedure to define a new home point... just do that procedure from overhead where it can see enough sats
  6. 4wd
    4wd
    North York Moors
    Typically it will get enough satellites once above trees etc - the issue is you won't have a known home fix so best wait and watch the LEDs to see it do it once up there - or reset it manually if not sure
  7. Fyod
    Central EU
    Great, thanks everyone! I'll try it out and report back.
Similar Threads - Launch satellites locked Forum Date
Launching and landing from a yacht. Phantom 4 Pro Discussion Aug 1, 2017
Can't launch phantom 4k General Discussion Jul 21, 2017
Why does GO 4 auto-launch itself? Phantom 4 Help Jul 19, 2017
Phantom 3 Standard won't rev or launch Standard/4k Discussion Jul 13, 2017
Launch/recover from moving boat Pro/Adv Discussion Jun 13, 2017
