Large purple interference
Ever since I have had my phantom 3 when recording video I will get a large purple line across the recording intermittent . It is on the recording and not just the monitor. Any ideas?
Is that the recording on the s/d card inside the phantom. Or on the tablet/phone momory ?.
Only thing i can think of is make sure the connecting ribbon is pushed all the way in at the gimbal. But im sure someone on here can help you out.
I just had a similar issue - the image was even worse when I could see it and most of the time was "not connected". At that point I couldn't record anything.
The culprit turned out to be the gimbal ribbon cable. Once replaced, all was good again. I tried re-seating the connections but that didn't help. The cable was defective...
I have the same or similar issue.
Mine has about 10 plus purple lines running down the screen,
I also see then on the table screen as well as watching back via the SD in my laptop.
Am I best changing the ribbon? is this an easy task ?
wkflysaphan4
