Depending on which unit you have, you might also consider upgrading to the Inspire phone/tablet mount which is stronger than the stock mount and will provide a slightly better anchor for the lanyard strap.
How do you prevent the RC/tablet from tipping forward (controls/tablet) with a lanyard based tether?
The RC center of gravity is towards the rear of the RC in relation to the tether mount when you have a 9.7" tablet that the whole thing flops over unless I hold it. The point of this is to make it where you can let go of the RC.
I tried making something that I could counter the tip over tendency using a tether to my belt but you need an anchor point at the front and bottom but you only have a potential anchor in the rear and you need the belt tether to be able to stretch so you can push the RC away from you if needed.
