So I just got my P3 yesterday and I did the firmware upgrade today but just to make sure I want to ask you guys if this is correct. I copied the file on the sd card and put it into the phantom and after about 30 min. or so I came back and took it out( no I didn't hear any beeps because I was away) and I plugged it back into the pc and this is what it says ' The firmware on the SD card is identical to or older than the current firmware on the aircraft' so thats done I guess? already had the right firmware right? and then I did the same with the transmiitter and it says '
Abort
The firmware on the SD card is identical to or older than the current firmware on the remote controller.' so is that good too? I just want to make sure so don't be to hard on me. Yes I did read the entire manual, but just want to double check. And one more thing guys, with my old phantom v2 I had a download I could plug my bird into and check all stats and make adjustments. Is that not available with the P3? How do you calibrate your transmitter?
Abort
