Yes, if its big enough and/or you are good enough. Sure.I can tinker around with my P3A in my garage on Atti mode, correct?
Ok thanksYes, if its big enough and/or you are good enough. Sure.
Also, there will be debris flying around so don't be surprised when that happens!
Then I'm sure to get interference, correct? Just messing with camera settings and a few other things. Not looking to fly, but I do need to get it in the air. Otherwise I would remove the props and do it inside where it's nice and dry at the momentYou'll need to be in P-Mode though if you want to utilize VPS.
I would share a video someone posted on FB, but it's not mine. With my experience though I think I'll stick to your advice and fly outside tomorrow.It's not a good idea unless you have a 10-car garage and it's empty. Fly outside
You have to be in GPS mode to use VPS? That can't be right...
VPS is for indoor use (when GPS isn't present). Am I missing something?
If you re-read the manual's description of the modes, it is specific that Atti Mode doesn't use GPS nor VPS. Just the barometer.
Lol.. Good point !Thanks. I had no idea. Then again, I have no intention of flying indoors. What are the best settings for indoor flight? I assume P mode with RTH set to hover. If you have RTH set above the ceiling you'd have a real problem if you lost signal...
